SoundGuy
Apr 07, 2019Explorer
philh wrote:
I just thought of trying to suck through the winterizing hose. Anything other ideas?
Pump needs to be primed so yeah, stick the winterizing hose in a jug of water and turn on the pump. Check also that the city water inlet check valve isn't leaking air into the system - a threaded male 3/4" plug will do the trick for this.
If you want to truly quiet the pump once you get it running check out my solution in my gallery. :B
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
