philh
Apr 08, 2019Explorer III
garym114 wrote:
You say the inlet valve is open. You need to make sure the pump is taking suction from the water tank. Fill valve for tank is closed and city water connect is closed.
No city water valve
Fill valve is not designed to be air tight
For the other suggestion, there is no filter on the inlet side.
I will take a bucket of water and try priming the pump.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
