philh
Apr 12, 2019Explorer III
opnspaces wrote:
Yeah one of the problems with help over the internet, especially without a picture. I for one assumed that it was a three way valve, not a standard ball valve.
Winterizing valve
Is there possibly a way you can set the valves so you can blow air or pump water through the winterizing valve and back to the fresh tank?
tank---ball valve---T connector---pump
---winterizing tubing---ball valve---T connector (above)
If the tank ball valve hasn't failed, and it does "feel" normal, then I should be able to blow into the tank. I can not blow into the tank.
I have an appointment to take it to the dealer in two weeks. I'm speculating a crushed or crimp line from tank to first ball valve.
