DReisinger's avatar
DReisinger
New coaxial to antenna
Want to pull new cable from booster to antenna, which one on back of booster goes to antenna. The one in the bedroom is orange but there is no orange one leaving back of booster
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Another thing to consider. There are usually two INDEPENDENT lengths of coax between the switch and the antenna.. One runs inside the wall to a connector at, or just under, the roof line, this cable is protected from the effects of the sun and may well outlast you..
    The other is from the roof to the antenna and 99% of your cable problems are with this run.
  • Is it possible to pull a new coax from the wall plate up to the Batwing on the roof, or is there too many interferences , is that cable installed when the unit is built?
  • Looking at the back of the plate the cables from left to right are:
    antenna in...cable in...2nd tv
    won't waste my time trying to post a picture but here's a link:
    wall plate
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
