nebmike
Mar 24, 2016Explorer
MudChucker wrote:
Anything restricting the air flow ?
Does the furnace kick off before the temps on the thermostat is reached ?
Enclosed underbelly ?
Enclosed underbelly (no gaps). Nothing at all restricting air flow.
If I move the thermostat below the inside temp, the unit will cycle off as normal... burner shuts off then a short time later the fan stops. But with the thermostat set between 65-70 the fan runs constantly and as I mentioned, it seems as if the burner cycles on/off occasionally.
Propane tanks are full and if I light all three stove burners while the furnace is running, they all burn at what seems to be 'normal', which makes me think its not the regulator.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
