dougrainer
Mar 24, 2016Nomad
What Model/BTU furnace? From your description, the Hi limit is kicking in and out. That means that either there is a restriction in one on the Furnace hoses or they did NOT run enough hoses to allow the furnace to run correctly. There is a specific amount of exhaust vent hoses to allow the furnace heat to run thru out the RV. Also, it is not unusual for the OEM to install a TOO Small BTU furnace. Your model should have at a minimum at 30k BTU furnace. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
