Old-Biscuit
Mar 25, 2016Explorer III
Chris Bryant wrote:nebmike wrote:
One final question for you fine folks... during all of this I noticed that the rear panel on my furnace (where the three main ducts come off of) is a bit crooked and there is quite a bit of heat escaping around the edges of it. Would it be worth my time to tape it with some aluminum tape or just leave it be?
Seal it up. That hot air will be drawn back in to the return, causing overheating.
That was probably original issue with 'limiting'
Addition of extra duct allowed more discharge flow that was most likely blowing out around gap at a higher rate/temp.
Sealing that leak would have probably cured initial issue w/o new limit switch, new additional duct and new registers.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
