Vulcan_Rider
Aug 02, 2015Explorer
RobertL0 wrote:
When in AC mode, (fan speed set to low or high), the RV will get to it's set point, then the compressor AND the fan will shut down at the same time.
For me to restart the cooling, I need to shut off the AC via the thermostat, and then turn it back on.
Sounds like normal operation to me. If the fan runs all the time, your humidity control will be VERY poor.
This is how my house and RV work.....and even some window A/C units too......except for the restarting part, that is.
Are you SURE that turning the temp down 5 degrees or so will not cause it to restart ? (Some will not restart within 5 minutes.)
It is possible that your stat just has too wide a range to keep things comfortable.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
