RobertL0
Aug 21, 2015Explorer
Was this problem ever resolved?
lenr wrote:
Our newly installed tstat and control board now seem to be not starting up on auto fan. Had it set to 62 with the tstat saying it was 77 with no start. Finally took off and ran after several cycles of the push button thru tell heat-off-fan speed-a/c positions. Can't find a tech support number for Domestic--they only talk to dealers. I don't believe this is a dead band issue. If the dead band is this wide, then this tstat is total junk. The manual says it will switch to high fan when 5 degrees from set point--it does not say there is a 5 degree dead band.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
