RobertL0
Aug 22, 2015Explorer
Thanks, but I am able restart the unit immediately by shutting it off, then on, via the thermostat..I think high head pressure would prevent me from starting the compressor immediately
MM49 wrote:RobertL0 wrote:Your problem is real. I have a new Sunny Brook with the same issues. It seems like it is cutting out from high head pressure. It resumes later. This only happens in very hot weather.
For me to restart the cooling, I need to shut off the AC via the thermostat, and then turn it back on. The problem will the repeat itself.
I would rather do the work here, then leaving the RV at a service center for a few days if I can, especially in the mid of summer camping.
Think replacing the thermostat will do the trick? Are there better thermostats out there than the Dometic?
Thanks in advance
MM49
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
