helperzack
Sep 14, 2013Explorer
It may have been plugged into shore power when I did it. Red cable to +, Black cable to -.
Now to find the fuse in the converter circuit. Would it be located under the cabinet where the converter is located??
I am getting no charging from shore power. When I start the engine all lights come on bright, so alternator is working.
Still the steps do not work. I tested the back of the step switch this afternoon and had right at 12.43volts, as I would toggle the switch from in to out it would reverse polarity + to -, which is as it should.
Still stumped. Will post if/when I find the problem. Thanks everyone!
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
