westend
Sep 15, 2013Explorer
Sounds like you have more than one issue. First, check your converter with a handheld meter. When powered, the converter should be 13.xx volts at a minimum.
If you had a shorted cell in a battery and tried to operate a device (like the steps), the amperage may have been high enough to either burn a wire or fry the device, if it's not fuse protected.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
