BFL13 wrote:
Ok, with controller to battery connected, but no connection to panel wires, do you get battery voltage at the controller to panel terminals? And a display light showing battery connected, but not the panel?
Is the fuse on the positive wire between battery and controller ok?
With no wires connected to PV panel terminals, the voltage reads zero.
The yellow battery status LED is on at the present time with battery voltage reading 12.38v.
No in-line fuse holder is installed on the positive wire between battery and controller. Just the wire between battery and controller.
