time2roll wrote:
unbob wrote:
time2roll wrote:
What voltage do the output terminals read?
I assume you mean the 'load' terminals - they read exactly the same as voltage measured at battery terminals (currently 12.38v).
No I meant the output terminals to verify the battery was connected properly.
I would disconnect solar. Disconnect from the battery. Then reconnect for one more try. Otherwise yes I think it is shot.
Any chance anything was connected with reverse polarity?
Does the manual suggest anything?
Manual states the following:
Battery Reverse Polarity
Fully protected against reverse battery connection. No damage to the controller will result. Correct the mistake to resume normal operation.
PV Reverse Polarity
Fully protected against reverse solar connection. No damage to the controller will result. Correct the mistake to resume normal operation.
and this ...
Self-diagnostics and electronic error protection prevent damage when installation mistakes or system faults occur.
