dclark1946 wrote:
Johnny G1 wrote:
unbob wrote:
dclark1946 wrote:
So I am also having an issue with my new Morningstar Sun Saver 10A controller but it is different from the OPs. Mine seems to operate normally when the two 55W panels are in full sunlight but in the late afternoon or sometimes early evening the status led changes from green to full on red and the battery status leds are sequencing red,yellow,green. In the the controller stays in that state even with the panels illuminated by the sun (low angle) but later in the day the controller goes into normal charging operation with the expected charge and battery led status Being as expected.
I have discussed this with Morninstar tech support and they are sending me a replacement controller. I am wondering if they are having quality issues with their off shore supplier.
Solid red status LED is a "critical error" (see page 29) and the battery status LED R-Y-G sequencing is "Self-test Error" (see page 37).
Had the same problem on my truck camper, disconected charge line from truck and problem went away, no explanation for over charging with 2 power leads????
So are you saying that you were charging both your camper battery and your truck battery using a solar panel?
No I am saying that I had a charge line from my truck alternator to charge my camper batteries and was also using my solar too, nobody can figure it out as I can have my mh plugged in to electric and still be charging from my solar. The problem showed up when I had park and shut off my truck, Just happened to look in at my batteries and noticed the light's flashing. my batteries were optima blue top.
