bedpan
Jun 25, 2015Explorer
Thanks folks...
I like the idea of stuffing some insulation in the cavity above. I will pull out the baffle and seal with some reflective tape. Not sure what the current baffle is made out of. If it is non-conductive I will cover it with tape as well.
Will look into adding some fans. Will have to look at some of the thermistor kits and see if I can get it to switch on and off automagicaly. Run it off the fridge circuit so it only can run when the fridge is on and the heat above a certain threshold.
Any off the shelf kits for doing this or do I get to jerryrig this myself?
Mike
Mike
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
