Old-Biscuit
Jun 26, 2015Explorer III
bedpan wrote:
Thanks folks...
I like the idea of stuffing some insulation in the cavity above. I will pull out the baffle and seal with some reflective tape. Not sure what the current baffle is made out of. If it is non-conductive I will cover it with tape as well.
Will look into adding some fans. Will have to look at some of the thermistor kits and see if I can get it to switch on and off automagicaly. Run it off the fridge circuit so it only can run when the fridge is on and the heat above a certain threshold.
Any off the shelf kits for doing this or do I get to jerryrig this myself?
Mike
Fan thermostat kit...........LINK
Goes on far right condenser fin (set of fins at upper vent)
12V + to t-stat then to fan(s)
You can put an On/Off switch in line.
Powers fan when condenser fin temp reaches 130*F.....opens when fin temp drops below 115*F
Install fan center line, mid position of fridge
Some wiring, switch, computer fan, t-stat kit......done
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
