MrWizard
Jan 01, 2015Moderator
New Years Surprise, Burnt Solar Wiring
yesterday solar yeild was low..for a sunny day
Today about noon i open the bay to check the watt meter
NO amps no voltage, display on the 2000e showed ZERO's
grabbed the Fluke and read 20.00vdc OCV on the wires from the panels
open the the controller and found this
the burnt wires are the ones coming from the panel, and it is the black wire that got the hottest and burned and melted everything
NO loose connections, lugs and wire terminals tight, took some effort to break the screws loose and remove the wires
will be performing and autopsy on the controller
so i cut some wires pulled the controller and installed my backup Xantrex controller
i think i will be looking for a another controller
at least 30 amps
the xantrex is 40amp PWM, But has one 'quirk' i don't like, (when i tested it before) after 4hrs of charging it drops to float, even if the batteries are still absorbing at a higher rate
will see how it does over the next few days
at least 30 amps
