opnspaces
Apr 08, 2022Navigator III
There's nothing wrong with your meter. Or at least nothing wrong enough that you can't trust it for troubleshooting this issue.
Go back to the trailer and turn on the 12v. When it fails check voltage between the tongue mounted circuit breaker posts and the negative post on the battery. If you get battery voltage on one post and a different number (most likely 0) on the other post replace the circuit breaker. If the new breaker trips there is a short somewhere in the system.
New breakers are available at any automotive parts store.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
