wing_zealot
Sep 27, 2019Explorer
If you turn off the circuit breaker to the converter and "that shut off a bunch of stuff", then:
1. your battery is dead, or
2. the disconnect switch on the battery is turned off, or
3. the battery cable(s) are disconnected.
Any of those scenarios will mean the converter is under load and more than likely your 12 amp draw; and causing your overload issues.
