wnjj
Sep 27, 2019Explorer II
brows827 wrote:
These are great responses - I can't thank yall enough for your responsiveness/willingness to help. It's frustrating how little info there is in manuals on this stuff.
I won't be home until this afternoon - but I will check the water heater switch near it (or if I can't find that, will look for the breaker) - that may be part of what was causing the issue, as I have never turned the interior switch for it on - which is why the hot water was surprising. It would make sense that may have been a contributor or the cause (would be really nice if that's all it is), since it seems to intermittently jump on after a while.
I'll also check the voltage in the rig and post my findings.
If you never turned on the water heater and yet you have hot water, I'm sure that's what is causing it and likely nothing else is wrong.
