MrWizard
Sep 27, 2019Moderator
re: power converter online: I tried switching the circuit breaker for the converter to off, but that shut off a bunch of stuff. How should I handle shutting it off?
Most things in the TT need 12v , either from the battery or the converter/charger
Fridge controls, lp sensor, lights, water pump, Gauges, water heater control, furnace/heater
Battery should be connected unless RV is in storage without shore power,
You turn off converter with no battery, yes everything is going to stop working
once the battery has reached full charge
The converter will use very little 120v power, to maintain the battery
