brows827's avatar
brows827
Newbie Electrical Issue - Advice Needed Please
Hi all - I'm hoping someone can help me out. I bought a 2014 Rockwood Roo 19 a few weeks ago, and I'm having some electrical issues.
At first, I hooked up to shore power from my house (running on 20 amp breakers with a heavy duty extension cord), and it kept on tripping the breaker after 30 minutes or less.
I also bought a 3500 watt inverter generator, as we're planning to do some boondocking camping, and tried it last night and encountered some issues - which is no good as we're planning to take it out tonight for the weekend.
I start the inverter up and plug it into the camper - and it will show that almost nothing is used.
Once I turn on the AC, it runs fine for 30-45 minutes, showing around 14 amps being used -- but then the generator jumps and shows that the camper is needing 25 amps -- (which is the max for the inverter) for no apparent reason - and will trip the 120 volt circuit breaker on the generator if I don't turn off the AC.
What's really odd is that once I turn the AC off, it shows that there's now 12 or so amps that the camper is using -- though there's absolutely nothing in the camper turned on, and the battery is disconnected.
Definitely would appreciate anyone's advice. I've searched for answers and haven't been able to find anything - except that maybe there's an issue w/ the AC? But that wouldn't explain the issue where there's still a draw after I turn it off.
Thank you in advance -
  • Hmmm, I been running my 13500 ac for almost two decades plugged into the outlet in the garage. Matter of fact it has been running for a week as I type. :h
  • Chris Bryant wrote:
    I would bet on electric side of water heater being on.
    X2
    Call me if you wish
  • 20 amp lines will have a hard time running an RV a/c. Especially starting and can supposedly damage the a/c eventually. So running that maxes out the power supply and running anything else significant will trip the breaker. You need a 30 amp line to run that a/c
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
