jornvango's avatar
jornvango
Explorer II
Mar 25, 2019
Newbie question about solar charging
Every time I think I have somewhat of an idea of what is going on, I seem to get completely puzzled again!
We have 1 AGM battery in our trailer. While boondocking in full sun, our 100W solar panel shows the battery is almost full and the following: 14.4V, 2.8 Amps, 10.9 AH
Then, I plug in a small inverter in the trailer (one of those small inverters to use in a car and I plug it into the 12V cigarette lighter port in the trailer) and connect the laptop to the inverter's 110V port for charging. The laptop is a regular Dell laptop and the laptop AC adapter shows on the label:
- input 100-240V, 3.2 A
- output 19.5 V, 10.8 A
After a few minutes of having the inverter and laptop plugged in, I check the solar panel controller and it is rapidly going down. When it is down to 13.2V and the battery level indicator (on the controller) shows as 50%, I call it a day and unplug the inverter in the trailer, worried that the inverter/laptop charging will drain (& kill) the AGM battery if the solar panel can't keep up.
What's going on? For someone who knows what those numbers mean... :-)
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
