RJsfishin
Oct 20, 2019Explorer
Antifreeze probably ok for the winter.
As far as I know there is always a pump switch on the monitor panel.
The other switch you describe sounds more like a circuit breaker, If it doesn't stay in the reset position, there may be a short in the water pump circuit somewhere.
The pump runs on 12v only either from the battery or the 12v converter when plugged in to shore power. All the 12v stuff runs on battery all the time, the converter charges the battery when plugged in.
