learningsolar
Apr 14, 2014Explorer
MEXICOWANDERER wrote:
Two volt MINIMUM incoming versus outgoing for a controller to work correctly. So 13.0 volts is not the hot setup. You need a DC to DC booster before the controller to do it the way you described.
is this voc?? if I am understanding then I would need min 17 voc on hot cloudy day? when panel is at temp and least sun available??? I can achieve that with the 60 cell I believe with two circuits....I think...more testing to come
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
