learningsolar
Apr 14, 2014Explorer
JiminDenver wrote:
What is the rated Voc for each panel?
You can get the tracer 40a mppt for around $200 or so altho we still haven't seen any one actually successfully using that series of controllers yet.
Temp sensing at the battery is important if you deal with excessive heat or cold. Some controllers like the Eco-worthy have the sensor inside of it so as long as it is in the same conditions as the batteries, the affect is the same. Most low end controllers have no sensor at all.
There are advantages to both mounted and unmounted panels. Those with mounted tend to over emphasize the time and effort it takes to set them up (10 min) and turn them (5 seconds) and then discount the extra amps to be had early and late when mounted panels are barely putting anything out. In other words my single portable is worth both of yours mounted.
These panels are not rated and have never been flashed when manufactured, they were rejects before that process...and as far as mounted...after system is put together i would bet that mine will be a quick connect attachment to the roof and be able to be placed else where, but at about 6 feet long, 3.5 feet wide and 30 lbs....not the easiest to setup and take down...but i guarantee it will be first mod to the system after done....welding up braket to mount on boat rack of tent trailer, which also makes it easily accessible to take off to setup...
and i know there is snow in the background but i have no intentions of using these in the winter, just on tent trailer
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
