BFL13
Apr 14, 2014Explorer II
I don't know that controller if it is fake MPPT or not. It says high set point is only 13.7v though, which if true is too low except for a float charger.
http://www.ebay.com/itm/MPPT-30A-12-24V-SOLAR-CHARGE-CONTROLLER-POWER-BOOST-30-/251499076765?pt=LH_DefaultDomain_0&hash=item3a8e835c9d#ht_4712wt_1001
Some of us on this forum have the 20a Eco-Worthy and it seems ok. You would need one for each 240w panel and then the two controllers could go in parallel on one battery bank or one to each bank if you have a split bank.
I will be starting to use mine on a 230w panel later this week for an extended period and will be reporting on how it does.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
