Nov 30, 2018Explorer II
I have the S-350-12. They have 3 terminals per side. I used 6, 3' 10AWG stranded. I crimped 12/10awg fork terminals on each wire for the power supply end and bundled the 3 and crimped a 8awg eyelet on the battery end. Make sure the terminals for the power supply end will fit the power supply terminal strip.
To measure current I bought This. If you don't have a voltmeter you may be better off with This
I adjust my power supply output to 14.5V before I connect it to the battery to allow for line loss. When it gets down to 1A my battery voltage will be ~14.4V.
A timer is a good idea, set it and forget it
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
