MEXICOWANDERER
Nov 30, 2018Explorer
https://www.ebay.com/itm/Intermatic-FD6HH-6-Hour-Countdown-Decorator-Decora-Style-Timer-Switch-SPST-Ivory/162914076971?epid=1901006316&hash=item25ee6f892b:g:cWYAAOSwPb9ajvPl:rk:2:pf:0
This one even has a HOLD which should only be used when the power supply is set on long term voltage maintenance better known as FLOAT.
It is installed between the wall socket plug and the power supply.
This is a LIFETIME switch. When your children are in a rest home, this switch will still work fine. It is not a chew and spit purchase. It needs a PLASTIC duplex box and two ROMEX wire strain relief clamps from any hardware store.
And ALL of my seven Megawatts have an actual measured and remeasured ADJSUTABLE voltage range between 10.07 volts to 15.47 volts. Is there some Kryptonite battery out there that this will not agree with?
Meanwells are different. choose the dash fifteen model like the 1500 watt model that is the basis of the charger I am building. Because of the micro-soldering needed with the HIROSE connectors I DO NOT recommend this model for folks wishing knob adjustable remote voltage control.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
