Dec 15, 2018Explorer II
My Megawatt S-350-12 goes into constant current mode (CC) at about 32A and the voltage folds back accordingly. No hiccup. I've operated it in this mode for maybe 10 minutes at the most so I do not know how it would hold up long term. I can't speak for the other models.
Side discussion maybe of interest: I'll put the DROK 1500W Boost Converter to the test this afternoon so I may put the Megawatt in CC at that time. I'm currently slow discharging one of my 29's for the load. I'll have the Megawatt output set to 13.4V and the boost converter output at 14.4V, common ground. This little converter will charge the battery or die trying, all currents adjusted wide open. The boost converter will shut off the output if the Megawatt output drops below 10V. It will start hiccupping at that point.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
