DieselBurps
Dec 15, 2018Explorer
Well I screwed something up or I am missing something. I got the **** thing hooked up, but when I check the voltage with a multi meter on the pos. and neg of the Megawatt I get 2 volts? Seems weird. WIth the the Megawatt on but not hooked up to the batteries, it shows 14.8 volts on my multimeter. I am confused about why I am getting two very different readings. My batteries are 6 volts in series.
When I check the voltage of the batteries, across the positive terminal on one battery and negative terminal on the other battery I get 0.02 volts, but when I check the battery individually out of the camper they show 6.2 volts. ?? I know the Megawatt is working because the fan comes on, and over time I can feel the cables from the Megawatt to the batteries get warm, also my Trimetric inside the camper shows the voltage rising, it started out dead at 10 volts and quickly when to 14.0 volts over an hour or so.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
