MrWizard
Dec 15, 2018Moderator
When I check the voltage of the batteries, across the positive terminal on one battery and negative terminal on the other battery I get 0.02 volts, but when I check the battery individually out of the camper they show 6.2 volts
Need to check that battery wiring
if series they are 'end to end' backwards
or in parallel even backwards
but even if parallel properly for 6v, they make a low resistance short to megawatt
14v trying to charge 6v
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
