skipnchar
May 11, 2013Explorer
Black wires are positive and white wires are ground. I ASSUME that since you're using 5 batteries, they must all be 12 volt batteries so you wire them positive to positive and negative to negative all the way through with the two unused poles on two different batteries, going to the trailer. The 5th battery would have to wire exactly as the other four are wired.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
