MEXICOWANDERER's avatar
Apr 16, 2018
Nightmare Reducing Battery Charging Voltage Corrector
Yeeco QUERY AMAZON UNDER SEARCH
Yeeco DC DC 10-60V to 13-97V Boost Voltage Regulator Power Converter 1500W 22A Volt Transformer Power Supply Module Board with Adjustable Potentiometer & Heatsink Fan
  • 22 amps max current
  • Only the very BIGGEST truck to trailer cable will pass more current than that
  • Set the charger at the voltage YOU dial in and FORGET what factory idiots tell the alternator to do
  • CORRECTED VOLTAGE only goes to the trailer
  • The tow vehicle stays at the factory idiot setting
  • Want 14.40 EXACTLY for Lifeline batteries -- you got it?
  • Need higher or lower set voltage...you got it.
