Bobbo wrote:
dons2346 wrote:
smkettner wrote:
What about when stopped? Many OEM inverters have an ignition lockout so that you will watch the road and not the tv.
Never heard of this before
This is common when there is a television set where the driver could possibly see it. That outlet is disabled when the MH engine is running. If it is a towable RV, this does not apply.
This is not a function of shutting the inverter off, the inverter will remain on until it is turned off at the inverter itself or its remote control.
Turning the TV off when the ignition is on is a function of the interlock device that the TV is plugged into.
