Giselle
Oct 15, 2014Explorer
twainharteartist wrote:
My generator is surging so I pulled the carb and cleaned it and checked the floats and needle valve. The generators engine was surging and I was getting 110 power till I pulled the carb. I checked all the brakers. I was getting 110 power to the micro wave and two of the plugs but not to the plugs to the TV up front and two of the plugs up front. I changed the main braker because it was bad. Now I can't get power to any of the 110 plugs. Any ideas?
The first and the formost thing suggested is to turn off the main power switch and put it back on. make sure all other swithcer arre off as well. only on la swithc to make swure you have to power should be on. if it dosent work and then you my friend have to go circuit by circuit. chekc them individaully.. GFI can also be the factor.
