twainharteartis
Oct 22, 2014Explorer
OK I have the Generator running good so I checked power at the gen. I have 110 going from the gen to the main power panel. I checked the breakers at the power converter and found some tripped. I reset them and the power converter shorted out. The breaker for the receptacles was tripped again. So now I need to replace the power panel and I think I must have one (or more) 110 receptacles that have a short. So you electricians out there am I thinking right on this?
this is the converter that is in my motorhome (1997 Damon Intruder)were can I get a replacement?
Series 6300 A, Model 6345. Class CTL panelboard- type-1.electrical rate: Max 30 Amps vac. options code: 17-9725
Electrical rating: 7.8 amps 120 VCA 60 HZ output:45 amps 12 VDC. 12 VDC fuseblock - Max branch circuit fuse size: 20A (average charge rate : .5 Amps)
