Lynnmor
Oct 18, 2013Explorer II
You need to find it now. A bad connection can get hot and possibly cause a fire. If you have the type of outlets that don't require a box, then the wires are pushed into a IDC slot for connection. Pull the outlets out and check those connections. Also, I've seen connectors that are inline, used for connecting slideouts, actually burn up.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
