wa8yxm
Oct 18, 2013Explorer III
We use electric heat in this motor home as much as we can. I mean why pay for Propane? Well one of the outlets (Of the kind shown above) bothered my nose when we used it (Hot wire smell is often followed by a visit from boys wearing heavy waterproof coats and carrying big hoses hooked to a big Red or Yellow truck with flashing lights on it, and that is something I do not wish on my motor home).
So I installed a Heavy Duty (15/20 amp) outlet with heavy duty wire next to it, I finally got around to replacing the overheated outlet.. Turns out the wire is still good. it was the outlet that was getting too hot. Though there is evidence of hot insulation (just not as bad as I feared)
The outlets are wired kind of like this.
{Breaker box}===={Outlet 1}===={Outlet 2}===={Outlet 3}====={Outlet 4}
(note two wires from between each item, There is also the safety ground)
If one of the lower number outlets develops a bad connection.. What you see is what you get. Also there is the connection between the neutral wire (White) and the bus in the breaker box
I found many loose screws in my breaker box
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
