NuttyKev's avatar
NuttyKev
No battery power
I have a Heartland Fuel toyhauler and just recently noticed my batteries no longer supply power to it. I park it on the side of my house and leave it plugged in to shore power. I went out to run the generator and unplugged the shore power. Generator started up without issue. Everything working as should be, lights, water pump, and i ran the A/C for a while to exercise it.
Turn everything off, shut down the generator, and i no longer have any lights, or power at all. I go through everything i can think of. check batteries, they are good (they started the generator). Check all the fuses, even replaced them just to be sure. Plug shore power back in, all good, unplug shore power, nothing. I check the little breaker next to the battery thats bolted to the frame, getting power to both poles.
Im at a loss. What else is there to check?
  • If the generator will start up with the shore power disconnected then as suggested look for a disconnect switch or possibly a stuck auto transfer switch.
  • No real idea, but could it have something to do with the Automatic Transfer Switch? Have you checked the Battery Disconnect Switch? Perhaps it got turned by accident.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
