Ok, so I finally was able to go get my new (to me) toyhauler. It's a 2004 Jayco Talon ZX 36Z. Hooked everything up, and I have turn signals and brake lights, I *think* the 12V constant is working...
Turns out it was a combination of TV and trailer wiring. 7 pin connection was shot, connections all corroded off. Where they spliced in the 6 pin connector, it was corroding and when it got wet current was arcing across pins. 6 pin not wired with at 12V hot, so won't charge the batteries. A couple bad grounds on the trailer A few other loose wires randomly around the trailer. Now, everything works and we're good to go!
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
