I have a 2008 Jayco f322 and I cannot get power to the brakes, I have a Tekonsha P3 brake controller and it shows over 3 amps going when you press the brakes, all the lighting works including the b...
Open the junction box at the front of the trailer where the ambilical cord connects to the trailers wiring and to the breakaway switch. Locate the blue wire. Have a helper apply brakes and check for voltage. Check ground wire connection at the junction box and from the trailer battery to frame of tralier. Disconnect blue wire and see if amperage goes away. Crawl under trailer and check connections at each of the brake backing plates where wiring harness attaches to the brake magnets.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
