JohnDoe
Nov 18, 2013Explorer
No Brakes
I have a 2008 Jayco f322 and I cannot get power to the brakes, I have a Tekonsha P3 brake controller and it shows over 3 amps going when you press the brakes, all the lighting works including the b...
JohnDoe wrote:The display indicates voltage sent to the trailer brakes, not amps. I'd suggest you read through the manual and make sure all your settings are correct on the controller. There is a "troubleshoot" function with the controller also.
I have a 2008 Jayco f322 and I cannot get power to the brakes, I have a Tekonsha P3 brake controller and it shows over 3 amps going when you press the brakes, all the lighting works including the brake lights ok , when some one presses the brakes there is no sound at the wheel, have checked them all for that, any one have any ideas
