JohnDoeExplorerNov 18, 2013No BrakesI have a 2008 Jayco f322 and I cannot get power to the brakes, I have a Tekonsha P3 brake controller and it shows over 3 amps going when you press the brakes, all the lighting works including the b...Show More
Old-BiscuitExplorer IIINov 19, 2013If you could free spin the wheel......need to adjust the brakes before you do anything else.Brakes should be adjusted until you can NOT turn wheel then back off the adjustment until you feel a slight dragAfter adjusting the brakes you can then set up the controller.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
Related ContentSurge or electric brakesBrakes grabbingBedding Brakesintermittent brakesbraking problem
