VEGASJOE_07's avatar
VEGASJOE_07
No city water
I just returned from a short trip in my 5th Wheel Rv. While set up in the park I noticed I had plenty of water pressure while using the pump (onboard water). However, when attempting to use the city wate connection I found I had intermittent or no water pressure.
Any suggestions on where to look for the prroblem?
  • Had same thing last week check washer screen in the water intake connection on the RV. Ours had some stuff clogging it.
  • Back flow preventer valve could have come apart restricting water flow.
  • Do you have a selector value for city water or pump? May be in the wrong position.
  • Had a similar issue a couple years ago. Turned out the Pressure Regulator went bad. With it connected, no water flowed.
    -Michael
  • City water connection........washer with screen clogged OR check valve inside connection is jammed up restricting flow or whole house water filter on city water line is plugged up.
    OR if you have a water/utility panel the valving was not properly set
  • Were you using a water pressure regulator? If so, it might be defective.
  • Your inlet screen if equipped could be clogged.
    Do you have an inlet filter?
  • sounds like the cG had problem, try it at home and see if you still have the problem.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
