MEXICOWANDERER
Feb 03, 2018Explorer
Try to access a parts book.
Sometimes the key to figuring out a puzzling design is to look at the entire part. Your local RV service center should be a starting point. Once access is made use a 12 volt test light and if power is showing on both sides of the switch disconnect one wire or a harness and check either for continuity or power on both sides of a disconnected switch.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
