ksg5000
Feb 03, 2018Explorer II
Chris Bryant wrote:SoundGuy wrote:DrewE wrote:
Some RV fridges have a switch of some sort that turns the light on all the time, using it as a little heater (for climate control or cold weather operation or some such, I can't recall precisely what at the moment).
Never heard of anything like this nor would it make any sense at all.
Called a Low Ambient Temperature switch or control (LAC or LAT). Used on some Dometic models. In low temperatures, the fresh food compartment stays at temp, but the cooling unit doesn't run enough to keep the freezer below zero, so they add heat to the fresh compartment, making the cooling unit run enough to keep the freezer cold.
On my fridge this switch is located in the freezer compartment door jam way up top - almost impossible to locate unless your looking for it. Open the door and look for black sitch on black trim.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
