rvpep's avatar
rvpep
No DC Power after shutting down generator
Hello all,
2023 Momentum 25G ,No DC power inside coach, electric jack has power. It started with my 12V Refrigerator chirping from low voltage 11.2 V. I started the generator and ran for 45 minutes after bringing the voltage up to 12.7 or so. When the generator shut down I had no DC Power in the coach. On shore power all DC works. 2000w inverter works regardless. Batteries have been plugged in and charging 12 plus hours; they're at 13.3V (lifepo4). And still no DC power.
I started testing from the battery back. Continuity was good on both inline 30A circuit breakers(frame mounted) and all fuses. Battery disconnect is on. I tested the battery dc in both positions. Inside: Panel:110 side no circuit breakers were not tripped, all fuses on DC side are good.?
2023 Momentum (less than a month old) 2- 100ahr 12V Battleborns, 660 W Solar Panels,50A mppt solar controller, WFCO WF8955 AD Converter. All factory or dealer install.
Any advice would be greatly appreciated,
???????Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
