mlts22
Jul 10, 2014Explorer II
I've seen someone have a portable crane (similar to what hunters use for getting cow/horse carcasses in and out of a truck bed) and use that to get their generator in and out without killing the back. At ~300 pounds full, the 6500 isn't going to be light, so a ramp or a hoist will be necessary.
As for the two Honda eu2000i generators, if you have a surface that you can bolt stuff to, I'd take a look at the LowPro LockDown generator mount for the eu2000i models. You unscrew the rubber feet on the generator, attach the top bracket, bolt the bottom bracket to a secure surface, plop the brackets together, lock with a hockey puck lock, and call it done. Cutting the handles won't do a thing. Of course, with the two Hondas, you can get an extended run tank for both of them as well.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
